Question about RCA D52W23 52" HDTV CRT TV
How do i change from 480p to 1080p on my rca remote
  • 985 Answers
You don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV reports the resolution of the incoming signal before it is scaled. If you have a BD player you can see the effect of changing the resolution setting from 480p, to 720p, to 1080i, to 1080p 60, to 1080p 24. The last three (the 1080 resolutions) shouldn't look too different with a Blu-ray apart from movement because the native picture is 1080p 24 and the TV is simply converting it back to 1080p 24 for display.
Posted on Sep 14, 2014
Anonymous
SOURCE:
I have a sharp TV and an trying to CD an Amazon fire stick. TV keeps responding...incomparable video signal...help
The stick is set to 1080p your sharp tv cannot show 1080p change it to 480p in settings , you will have to use it in another tv than is capable of showing 1080p, then just change it to 480p , then you should be able to use it on the sharp tv. You can then try to change it to 720p if it says the same about the signal leave it for 30 seconds and it will revert back to 480p
Aug 02, 2017 | Sharp Televison & Video
How to connect wireless insignia 2.4 headphones to our new Samsung tv modelun65ku630df
Get a optical audio converter box and connect the digital audio optical out to the converter box connect the red white RCA connectors to the headset base unit and off you go
Dec 25, 2016 | Insignia Audio Players & Recorders
TV was getting 1080p resolution Now 480p
Look in your menu for the resolution setting and change it back to 1080
Aug 14, 2014 | Toshiba 32L2400U 32" Class 1080p LED TV
Have a hiteker 37" how do you change from 480p to 1080p
The set should do this automatically depending on what is connected for signal and where.
Dec 06, 2012 | Generic Hiteker 37" Class LCD 1080p 60Hz...
Settings will not save
That is because most of the movies on tv are not produce in a 1080 p (Signel) Your lucky if there evan 720p, In High Def, 1080p is just a big hype to suck people in,
Dec 05, 2012 | RCA RTB1100 Rtb1100 Blu-ray Home Theater...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
My HDMI 1 input is set to display in 480p not in 1080p???
I think you have to change the settings in your HD box. Look on the diplay window of your HD box, if it says 480 there, thats where you need to change it so it will change then on your TV.
Mar 25, 2009 | Proscan 42LA30H 42 in. LCD Television
How to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Jan 25, 2009 | Toshiba SD6100 DVD Player
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
RCA D52W23 52" HDTV CRT TV Logo
271 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
