I just bought it in dec..2013...it still should be working,,please help
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
SOURCE: Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
SOURCE: my pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the
computer recognizes it.
Look for manufacturer-specific software to launch once you
plug your tablet into your computer; if this software fails to launch, it's
likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable
into a different port.
If the device doesn't charge in either port, replace the USB
cable.
AC Adapters
Some tablets are sold with an accompanying AC power
adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the
event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are
plugging your tablet into is defective.
If the device fails
to charge in different outlets, the AC adapter may be faulty.
Reboot
Like any device with an operating system a computer, a mobile
phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get
the operating system working properly again.
This is true of tablets too, but rebooting these systems can
be a little tricky.
Check the manufacturer's website for specific instructions
to restart your system.
Putting the tablet to sleep and waking it up doesn't clear
its memory look instead for the buttons
for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing
apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored
to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory
default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific
instructions, but as a general rule: plug the tablet into your computer using
the provided USB cable.
Wait for the appropriate software to load and then look
for a "Restore" option.
Follow the onscreen prompts to restore the device.
