A
Anonymous Posted on Sep 07, 2014
Need a manual for a sempre projection alarm clock
Lynda
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 25, 2015
Lynda
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5693
Points
I need instructions for Sempre Projection Alarm clock please. This was bought from Aldi over a year ago
Jermaine Gooden
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 59 Answers
  • Posted on Sep 07, 2014
Jermaine Gooden
Expert
Level 2:
New Friend:
Greenhorn:
Answers
59
Questions
0
Helped
13102
Points
188
Here is a pdf of the manual >> http://www.lacrossetechnology.com/5220/manual.pdf
  • J Roberts
    J Roberts Oct 30, 2020
    manual does not load
5 Related Answers
Anonymous
  • Posted on Jan 23, 2009
SOURCE: alarm clock came with chinese instructions manual,I need English
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Anonymous
  • 1194 Answers
  • Posted on Mar 19, 2010
SOURCE: Manual for Emerson smartset alarm clock
As you haven't mentioned the model no. so I am giving you a link from where you can download the manual for your appropriate model.
Good luck....and have a nice day. Rating the solution is highly appreciated.
Anonymous
  • 8197 Answers
  • Posted on Apr 24, 2010
SOURCE: Emerson cks3528 Dual alarm clock radio smartset
You can get the manual on the link below. Please alow time to load large file.
http://www.emersonradio.com/owners/SmartSet%20Series/CKS3528_110606.pdf
Good Luck and please rate 4 thumbs up for the free answer
Testimonial: "Thanks SO MUCH!!!! I've tried every button or set of buttons to set the "wrong" time zone for correct DST just to mess up Date too. Thank you SIR!"
Anonymous
  • 8197 Answers
  • Posted on Apr 29, 2010
SOURCE: alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Anonymous
  • Posted on Aug 16, 2010
SOURCE: instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
Where can I find the instructions for the Dreamsky Projection Alarm Clock radio?
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Sep 29, 2020 • Toys
Model # 93659 programmable alarm clock instruction please
It may be an Aldi Sempre clock although you only provided a number 93659. The manual also has a toll free number to call the manufacturer in case it is the wrong manual and they have another.
https://www.scribd.com/doc/304383460/ALDI-Sempre-Projection-Alarm-Clock-Manual
ALDI Sempre Projection Alarm Clock Manual
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
19helpful
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
1helpful
I need a manual to reset the projection.
Hello
I've the manual you need; for La Crosse WT5110 radio controlled projection alrarm clock. But I can'e send it to by this site, as it does not allow me to send such a large file. If you send me your email address by Fixya, I'll send it to you by return mail. OK.
10helpful
Instruction manual for a Tevion clock radio
Cant set alarm
http://www.oregonscientific.co.uk/files/manuals/RM313P.pdf
3answers
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
 Grubhead
Grubhead
SmartAviator
SmartAviator
