Pull rope pulls freely & doesn't spin engine
If its the old 3hp engine then they have a starter clutch fixed to the crank shaft. they have ball bearings inside and can sometimes get stuck or the gears can wear out. you would need a special tool to remove the starter clutch but you can prise off the top plate on the clutch to inspect the internal workings
SOURCE: starter pull rope broke. how do i replace?
Should be 3-4 bolts right on top of the pull starterhousing, take them off to replace string
SOURCE: the timing on my 3hp briggs and stratton mower is
Timing is fixed - or at least it's supposed to be! There is a possibility that the flywheel key has sheared, allowing the timing to drift, but not likely.
No-start on Briggs engines are usually carb related. Test for spark, and if good, overhaul the carburettor.
SOURCE: I have a Yard Machine Lawn mower by MTD it has a
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area.
Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... (
Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Thanks for choosing FixYa,
Kelly
SOURCE: Everytime I try 2 start the engine (pulling the
black smoke normally indicates exess fuel, try cleaning the air filter and replace the spark plug
