Guys, switch off the machine, move the needle to centre and move the needle lever also to centre using your hand and then switch on the machine ... it solved the issue for me.
That's an indicator that something is wrong with the machine, but it's usually user fixable. I'm going to assume that that happens when you attach the embroidery unit and turn the machine on. It indicates that for whatever reason, your machine cannot move the hoop to its default position. That could be because you have the small hoop attached (turn it on with NO hoops), the needle is not in its HIGHEST position, or the unit itself is not making a complete connection. Make sure that it is on solid level surface, raise the needle to its highest position (ALWAYS turn the wheel towards you), make sure the unit is making solid contact, and remove all hoops, and then try turning it on.
