Your set does not have a video input. However, if you check out the component connection instructions there should be something there about which input to use for just a straight video signal from older gear.
Did you try changing the input on the TV? Depending on the TV, it is usally labled which "port" it is. For example: You plug the Wii into Input 2. You'll have to change the input via the television remote to 2 in order for it to work. Look for a "Source" or "Input" button on the remote. If you are unsure which input the Wii is connected to, cycle through the Source or Input until it comes on.
Let us know if this doesn't work and we can troubleshoot some more.
What you need to do is connect your dish and wii into your RCA surround and then run a video lead to your tv. The audio out of the wii and the receiver need go into the inputs on the RCA receiver. Then, if your receiver does not have a video in and out you need to go to the output of the dish receiver to the input of the television. Let me know if all of these components are HDMI or not and I will change slightly how this is connected.
Input & Output HDMI 1.4 (3D Auto Setting/Return Channel):4 USB:3 Component In (Y/Pb/Pr):1 Composite In (AV):1(Common Use for Component Y) Digital Audio Out (Optical):1 PC In (D-sub):1 CI Slot:1 SCART:1 RF In (Terrestrial / Cable input):1 RF In (Satellite input):1 Headphone:1 PC Audio In (Mini Jack):1 DVI Audio In (Mini Jack):1 (Common Use for PC Audio in) Audio Out (Mini Jack):- Ethernet (LAN):1
Initially I thought the problem was going to be no composite input on this television. However according to the specs there is one composite (yellow, white, red) input and that is where you connect the wii. Is the problem that you've already connected something to the one input and you're looking for another spot to connect the wii? There is a wii component cable http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
Reboot the digital converter box by unplug,replug it back like 10-20 mins later.If u still getting the same problems no sound,tries by checking out the RCA cable connections,tries take out the red wire and check for damages and plug it back in or tries changes another RCA cable set all to gether.After new set of RCA cable should be working 100,if not the digital converter box is the problems,than now must change the digital converter box,this box no longer on sale by those big box stores.If u require to change the digital converter box tries websites like Amazon.com,Ebay.com to buy those converter boxes.
There's no "activating" it. It only supports a limited number of devices, and most of those are only usable in certain games.
The only supported USB devices on the Wii are:
1. The LAN adapter. Use the Internet Connection settings in the Wii settings menu to set up.
2. The Wii Speak is compatible with about 13 games. Change the in-game settings to use.
3. Any USB keyboard (usable in the Wii Shop and Internet Channel)
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
They are smooth silver posts with the inside showing a color, usually red, white and yellow.
Look for inputs marked Audio and Video IN.
The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
Do NOT connect your system to anything marked OUT.
Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input White = Audio Input Left (or Mono) Red = Audio Input Right
Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
Connecting to a VCR, DVD-R, Cable Box, etc.
In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
