To an iphone 4. And it has worked fine until yesterday
How do reset the H19txt to factory default
then re-pair.
Mark
Motorola Support
SOURCE: SAMSUNG BLUETOOTH PAIRING
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (Serched bluetooth device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
SOURCE: Music trouble
Not all bluetooth headsets can play music. If you hear music on your headset when you close your phone then your bluetooth is set for it. If not, you are unable to use that bluetooth for music.
SOURCE: The pairing light won't stay
Open the boom of the reciever right after the light turns purple... if you do it fast enough it will stay lit.
SOURCE: How to pair Motorola H12 with iphone?
I just figured it out myself!!
here is how:
1.) press your home screen button at the bottom of your iphone
2.) open settings
3.) go into your general settings (same gear picture as home page)
4.) touch to open bluetooth
5.) turn on your H12 headset and place close to your iphone
6.) turn on bluethooth on iphone and it will automatically find the headset
7.) touch the motorola H12 button and it will enable the connection
SOURCE: motorola bluetooth instructions n136 pair with IPhone
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
