I have been noticing an odor for some time on our clothing but now I'm smelling the gas inside the dryer. Again since then the main gas line shut off has been turned off and I am not using dryer. The valve and line to dryer have been checked and seem to be fine. I'm just wondering if there may be internally to repair.
SOURCE: smelled mild gas odor after moving dryer.
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
