In your Inbox, tap EDIT in the top right corner, then tap in the little circle of every email you want to delete, then tap TRASH. This deletes multiple emails.
You can either check each email you wish to delete and click delete once or check the delete all box to the left of the toolbar and then click on delete.
I assume the multiple messages you refer to are email messages.
If so, you can delete multiple messages as follows:
1. For messages listed one above the other in a row, use you mouse to select the first message so that is is highlighted. Then hold down your shift key and select the last message in your continuous list of messages. All the messages from the first to the last should now be highlighted (i.e., selected). While in this mode with the messages highlighted, press the delete key on your keyboard, or alternately, use your mouse and select the delete icon at the top of the email screen (it looks like a trash can).
You can also just drag the selected emails while holding the shift key down into your system trash.
2. For multiple messages that are not in a continuous list, while holding down the option key, use your mouse to highlight each message by clicking on it. When all the messages you wish to delete are selected, as above, press the delete key on your keyboard or use you mouse to select the delete button at the top of the email screen.
These instructions are for when you are using the apple mail program. It will likely work with other mail programs.
1. The video below shows how to delete a single mail message. To delete multiple mail message you would do the same thing except to delete several mail messages that are in chronological order you would select the top message...press and hold shift....and scroll down to the last message you want to delete and click on that message which will highlight all messages in between the firs and last message you selected. Release the Shift Key. And Delete.
2. To delete multiple messages that aren't in chronological order click on the first message you want to delete. The press and hold the Option Key (Windows Key if you have 3rd Party Keyboard) and select each message you want to delete and it will highlight all those messages individually. After you select all messages you want to delete let go of the Option Key and click on the Delete icon in the mail menu bar.
Important:
This places the deleted emails in your Trash folder within mail. To permanently delete the messages...Right Click on the Trash Icon or hold down Control and then Click on the Trash Icon and select Erase Deleted Items from the drop down menu and they will be permanently deleted and won't take up space on your hard drive.
Want to delete more than a single email message? You can easily delete multiple email messages from the iPad by using the Mail's edit feature. The button on the top right side of the inbox is the edit button. Touching this button will put your inbox into edit mode. Once your inbox is in edit mode, you can select multiple messages by touching each message you want to delete. You then have the option to either delete them by pressing the delete button at the bottom of the screen or moving them to a specific folder by touching the move button.
To delete multiple emails at once you can
select a range by clicking on the check box next to the first message,
hold Shift, and then select the check box next to the last message you
want to delete.
After selecting the desired range, simply click the Delete button. The selected messages will be deleted.
