The second hand of my Sector chronograph watch appears to be jumping in 4 second increments.Also the chronograph and alarm features do not appear to work with the second hand being stuck at 2 o'clock and it will not advance or reset when the buttons are pushed.Could this be caused by a low battery.
SOURCE: Aqualite Alarm Chronograph 4 button watch
good after noon ! press the adjust button hold it up to 3 second when the digit is blinking thats time to set press the mode to select the digit that you want to change after that press the stert or reset button to change no digit ! thank you ! god bless !
SOURCE: Sector 250 Chronograph Alarm
the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
pull the middle dial out to put it in alarm mode.
To set alarm:
-pull the center knob out.
-with it out you can now use the bottom (right) knob to set the alarm.
-pull the bottom right knob out one notch
-turn the knob clockwise or counter clockwise to set the alarm time
-push the knob back in (all the way)
the alarm is now set
if the center (right) knob is pulled out the alarm is ON
if the center (right) knob is pushed in the alarm is OFF
I have owned this watch for about 10 years now and love it.
the past few years the chronograph buttons (on the left side of the
watch) were not working well rendering the chronograph and count down
timer functions unusable.
repairing a chronographs is expensive and watch makers usually charge
several hundred dollars which is not a feasible fee for a watch of this
value so i decided to open it up my self and clean it up and that did
the trick.. its working like new!
enjoy the watch!
SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
