Cars & Trucks Logo
A
Anonymous Posted on Sep 04, 2014
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The alarms are just a couple feet from each other (near the door in both bedrooms), because the alarms are so loud and in close proximity, I can't be certain which alarm is sounding. I have read the manual that came with them and there is no explanation of the flashing/solid green light. I realize I can just change both batteries, but because smoke alarms can be so critical, I'd like to know what the lights indicate. Thank you for your help.
michaelst675
Level 2:
New Friend:
  • Expert 41 Answers
  • Posted on Sep 04, 2014
michaelst675
Expert
Level 2:
New Friend:
Answers
41
Questions
Helped
8463
Points
113
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
5 Related Answers
Anonymous
  • 393 Answers
  • Posted on Dec 03, 2008
SOURCE: car alarm goes off
is the battery the right one for the remote ie; size/voltage. check for lights inside (map,reading,etc) left on causing the bat to discharge.
Anonymous
  • Posted on Feb 24, 2009
SOURCE: problem with ford explorer alarm imobiliser
You should have a switch under the dash and then just turn it to the off position. If you don't or it doesn't work (like mine) then, there is 2 fuses under the dash, put the key in the ignition and turn it forward, pull one of the fuses out and then start the car that should reset it. Then you should be able to put the fuse back. Sometimes if you put the fuse back before starting it the alarm will just continue to try and reset itself, but not start the car. If that doesn't work I have a mechanic who can pull the whole alarm out and when hes done it would look like nothing has ever been installed. Hes very good. I ended having him take my alarm out when I had the same incident happen after the 2nd time.
Anonymous
  • 12 Answers
  • Posted on May 27, 2009
SOURCE: how to activate alarm 2001 bmw 325ix
The flashing light does not mean you have an alarm. They were not standard in the 3-series.
You can get one installed or if you want the dealer can program the lights to flash when locking and unlocking doors even with out alarm. This is called "acknowledgement without DWA"
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Apr 15, 2011
SOURCE: How to disable alarm system. The alarm went off
okay, this alarm reset is done by turning the key on and pushing the reset button a few times, you will need to try this a few times to get the correct number of pushes,for example turn key on and quickly push 3 times and if that doesnt work retrey it and push it 4 times, take note that every time you try you need to turn key off and then on again before you push reset button,i know it can be set to 1- 2 -3 or 4 pushes to reset, this is programed at the time of install, most installer dont set it or tell you so you will need to try all four. good day.
saailer
David Burbee
  • 1871 Answers
  • Posted on Feb 02, 2012
SOURCE: I have a factory installed alarm on my 2003 jeep cherokee ,how do i disable alarm
Hello! The drivers side door lock/unlock switch is more than likely defective...Having said that, the alarm system on Jeeps are a constant problem...To disable the system requires removing the drivers door panel and cutting the Light Green/Orange wire at the switch...And installing a 465 Ohm resistor...Not something done without the necessary skills...
I would have the vehicle towed to a Jeep dealer and have them test the drivers door switch and disable the alarm....Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Anyone their I need help with my viper alarm
If the control light for the Viper alarm continues to blink (basically it never stops blinking) then it is wired incorrectly, double check it's connection at the alarm 'box', ALSO, make sure no other wires are touching the control light's wires near connection.
2answers
Why low compression in 3rd cylinder?
If you have low compression on that cylinder you could need new rings on pistions but I am thinking maybe your problem lies in the valves. I would have the valves checked first.
2helpful
Resetting 1999 cavalier security system
If it's a factory alarm then you need to get it disabled by the dealer. if it's an installed alarm you need to unplug the brain/ module and your car should run
Smoke from under steering wheel while driving and all doors locked up solid and could not get out. Managed to lower a window and unlocked door from outside with key. No fire and emergency rescue was...
wiring has shorted out under the column ,looks like someone has played with wiring to fit a weekend boy racer alarm or remote start thingy and this is why the wiring has chaffed through and gone up in smoke
1helpful
The alarm (that I didn't know I had) on my 1997 Toyota Corolla went off when I tried to jump start it, and now I can't start my car at all. There is a brand new battery in there now, and the alarm keeps...
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
I recently replace the battery in my 2005 Ford Mustang GT. After I installed the new battery the green light for my dealer installed alarm keeps flashing even when I am driving the car. I went to the...
                Hi
                Before Battery Change
                • When was/or when did you notice alarm green light illuminated?
                • When after alarm was disarmed, did green light shine?
                First thing to check would be electrical connections starting from the battery.
                1. Follow positive wire lead from battery to fuse box connections. (Should be along driver side frame rail, or near battery.)
                2. Follow wrie harness to Relay Center. (Find Alarm Relay/Fuse)
                3. Also to Power Distribution Center. (upper driver corner engine bay)
                Relay Switch and Fuse to Alarm should be okay, given the alarm green light illumination.
                The Cars Brain, ECM Engine Control Module, manages messeges between power BattV and Alarm, also other modules and various sensors throughout the vehicle.
                When Battery Supply was disconnected, something happened, that stunned the memory in the ECM.
                Yes, the alarm does need resetting, its actually the memory messages saved in ECM need to be Refreshed.
                (saying "alarm needs resetting") sounds like alarm is broken, when that is not the case. Similar scenario is, when smart phone screen webpage freezes(alarm memory info in ECU). No buttons work, not even power button (Key Fob control). Only way to gain access is to remove battery.
                Lets try an experiment, this will be to loose still/saved frozen information, stuck in computer memory.
                How to Reset Vehicle Computer.
                1. Remove Neggative Post connection.
                2. Remove Positive Post connection.
                3. Let vehicle sit over Two Minutes, this time allows capacitors in vehicle Modules (ECM/PCM, TCM), to release any/all stored voltage, also any voltage in Vehicles ground circuit will be released.
                  • (I would typically wait 15 minutes) Capacitors with out constant Voltage input, will disipate rather quickly, depending on capacity size.
                4. With Battery Still Disconnected. Open Driver Car door, and turn Ignition to RUN Position.
                5. Reconnect Positive Post.
                6. Reconnect Negative Post.
                  • IGNITION is in RUN Position, when reconnecting Battery. Driver Door Is Open.
                  7. Turn Ignition to Off.
                  • Notice if alarm green light is illuminated.
                  8. Hit LOCK Button On Driver Door Switch to Reinitialize Alarm.
                  • Be SURE Key Fob not locked in car.
10helpful
2answers
I had to change the battery. After replacing the new battery all systems work, but the car won't turn over and the factory alarm is blaring. How do I disable the factory alarm? I do not have the...
If you have the Toyota factory alarm, there should be button under the driver's side dash to reset the alarm....Look for it 1st, then read below.
all the way just before cranking, to the ON position.
Then within 5 seconds, locate, press and hold in the
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
GL,
Td
Check engine light blinked continuosly and smoking
you have a severe missfire thats why the light is blinking
the smoke and sound were the cat converter[s] glowing red hot from the missfire
dont drive it untill the missfire is fixed or youll ruin the cats[if not already] plus a good chance of fire exists
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
