Select the model of your Uniden 5.8GHz system from the list beginning at scat=cordlessphones_mnl">http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=cordlessphones_mnl to download a copy of the manual.
It sounds like you have a broken output filter inductor in the amplifier. You should be aware that the speaker outputs of the amp are biased at ~40v DC and can give a good shock if you touch the speaker wire while you're grounded (touching the body of the vehicle).
When you connected the speaker as you did, I would have expected the speaker to move in or out and remain there while the wire was connected to the housing of the amp. I'll assume that the amp was screwed down to the chassis of the vehicle. If it wasn't, you may have more than one problem.
