The camcorder was left in the trunk of my sons car for a couple months while he was at college. I didn't know it until I went to use it and started getting the error messages. The battery charges, the display lights up but stays blue with the error message, the tape door opens but the carriage won't rise to eject the tape
SOURCE: camcorder tape door opening
I had a problem the same as yours and I found the problem on the ribbon wire connected to the board where all the control button is located ( stop, rew, play, fwd pause). The problem occur because everytime you eject the tape from the loading mechanism the ribbon wire also move like your cutting it into pieces. sorry for my english hope you get the idea.... wait for the photo and i'll show you what i mean.. hope this will give you the solution you need.
SOURCE: Camcorder error C31:23
I have a complete write up on my blog on how to fix this, you have to follow this. Or it will not work and you will still have the problem. Fixing the c:31:23 is easy just follow the steps.
www.wvstephens.blogspot.com
I hope this helps, if you have any trouble just leave me a comment with your email address and I will try to get back to you.
SOURCE: HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
SOURCE: Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
