The freezer side works well but the refrig. side is to warm
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
SOURCE: maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
SOURCE: Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
SOURCE: Maytag wide by side not getting cold freezer and
To make a long story short , If there is no frost on the rear wall , inside the freezer , then replace the overload/relay . Pt # 8201799 . This is the Whirlpool part number , which is used on Maytag also . This part comes with instructions .
