I am unable to connect to wireless network
There's always a reason but who cares if there is a good solution. Try rebooting your wifi router and then your PC and see if the connection returns. Also try to delete your WIFI network connection. Then reboot and it should return and so may your connection! If its a secure connection check if your password is correct by opening your WIFI network connection by double clicking it and clicking on wireless properties and then the security tab. Confirm your security key exists and is correct.
SOURCE: My pc is HP pavilion entertainment pc and i am
try to check your pc IP address may it not same setting with the wireless network, set it automatic may it work
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
