The Moen #1224 cartridge does NOT always come out easily! Sometimes the retaining nut (Moen part #14986) is jammed from factory installation and can even break on removal. Try soaking its threads with some Singer sewing machine oil overnight and then pouring a little boiling water on the nut to expand it at the same time as you start to turn it counter-clockwise with pliers.
Next you may find the cartridge almost impossible to pull out! You do not need a special tool. Just purchase a stainless #8 x 32 machine bolt and screw it well down into the threaded hole on the top of the cartridge. Then use a piece of wood like a scrap of 2 x 4 as a pivot point and put the vee of a pry bar under the head of the screw. Make sure you are levering upwards exactly vertical and you should be able to pop the cartridge out. Clean the hole and grease it with a little Vaseline before pushing in the new cartridge. See photos.
The make a cartridge puller you screw into the stem.... You can however use a vice grip and some leverage you must be able to grab the stem i believe you can put the screw that holds the handle into the stem then take a vice grip grab the screw then use a piece of wood to pry against and get it out the stem puller saves you a real headache pick one up at lowes or home depot
