2002 Toyota Camry Logo
Lorie Nowak Posted on Jul 02, 2009
Toyota rav4 cigarette lighter stopt working
Cigarette lighter donot work
  • Marvin
    Marvin May 11, 2010
    did you test the fuse?
  • Anonymous Oct 29, 2011
    the fuse for the radio keeps blowing each time i start the car all other fuses are ok...unplugged the radio and changed the fuse but it still blows
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Jul 02, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
4992
Points
42
Contact problem between source i have facing the problem few month ago
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1292
Points
According to Toyota manual you must use a genuine Toyota cigarette lighter part as sizes and tolerances are critical.
Wrong part can blow fuse or inpair correct operation.
1helpful
My cigarette lighter and radio stopped working in my 2000 Toyota RAV4...which fuses do I change to see if this will help the problem? I cannot seem to find a diagram on-line anywhere.
The fuse box cover will show the location of the fuses relative to their function, failing that check through the higher rated fuses for the lighter one.
1helpful
94 Toyota Tercel DX. 4 door
it is fuse # 1 in the fuse box under the dash on the drivers side it is a blue 15 amp fuse
Cigarette Lighter Pulled Out
there could be a wire in side the unit its self and that might have come dislodged
try it and let me know
Cigarette lighter socket not working
The fuse for the cigarette lighter is the 15 amp CIG fuse. According to my wiring book, the fuse box is either behind the console, passenger side for US cars, or under the dash, driver side.
1helpful
2answers
Cigarette lighter does not work
To test if the cig lighter works buy a 12volt test light at radio shack and test the center of the cig lighter to see if you get power there.if you don't then there is a blown fuse somewhere check the fuses in the engine compartment?
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
