Question about Microsoft LifeChat™ LX-3000 Headset
No sound I have adjusted volume but still cannot hear
    New Friend:
  • 17 Answers
Go to Control Panel--->Sounds and check whether the Headset is in mute
Posted on Sep 04, 2014
6ya staff
SOURCE:
Speaker too low, hard to hear. can i adjust volume?
What phone do you have?
On most phones there are buttons on the side to adjust volume.
There are also options for volume in your device's settings, under sound.
If it is hard to hear someone during a call you can turn on speaker mode which will make the sound a lot louder.
Oct 16, 2015 | Cell Phones
The volume on my acer aspire 6530 is to low although the control
if you have external speakers, try adjusting the volume there!
If you don't, then click on 281bf5a1-868f-4ef8-aedd-d25642705e45.png icon, click 'Mixer', adjust the levels.
Or click on Start, write in "Sound",4b2d9ebd-91e4-43cf-8490-3de18c6bc30c.png
Adjust the settings for device/s you use to hear sound.
Dec 18, 2013 | Acer Aspire 6530-5143 Notebook PC
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
I can hear them but they can't hear me
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 28, 2011 | Audio Players & Recorders
My built in mic is not working properly,when I call somebody hear me but I don't hear him!
If the other person can hear you then YOUR microphone is working fine.
The reason may be that his microphone is faulty (solution below)
Otherwise:
  1. Make sure the volume is turned up on your speakers (and if using external speakers they are plugged in / turned on) . To increase volume go to Control Panel, Sounds & Audio Devices and adjust the slider on "Device Volume" . Also click on "Loudspeaker Volume" and adjust the sliders there as necessary.
  2. Can you hear other sounds (like playing music or videos)? If yes then you need to adjust the audio settings for your calling program (skype or whatever). Launch the appropriate program Click on Tools and ' test audio properties' on the program tool-bar. Follow the instructions on the screen.
  3. Try plugging in headphones and see if you can hear better on them.
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 09, 2011 | Toshiba (P000257700) Microphone
I cannot hear the sounds and i cant click the volume because its hide
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there
hope this helps
Nov 30, 2010 | Computers & Internet
No sound
Hello endow1, hi, try this test, unplug you Logitech audio in plug and touch the input, you should hear a humming sound, Adjust the volume settings to high to hear it. If you cannot hear the humming sound, then there are problems you need to check. Place you speakers near your ear and adjust the volume Up and Down, you may hear a soft hum that should go up and down. Absence of the hum means that the speaker has loose connection from amplifier to speaker driver, or loss of power, check to see if there is pilot light.
Aug 19, 2010 | Logitech X-140 Speaker
I stopped having sound coming from the speakers. I checked and we are not on mute, and the volume is turned up high.
Make sure all your connections are tight and you have power to your speakers...Then go Start>Control Panel>Sound and Hardware>Sound, after you are in here make sure that your speakers are selected as default device.
Hope this helps, pls rate
Mar 19, 2010 | Proview Computers & Internet
H12 able to pair but no sound
Yes I would think that the unit is bad. If it is paire and you see volume level then there should be sound.
Dec 03, 2008 | Motorola Mobility Motopure H12 Bluetooth...
NO SOUND WHEN IM ON MAX VOLUME
There are 3 types of volume: master volume, in-call volume, and multi-media volume. To adjust master volume, press and hold the thumb wheel until the volume control comes up and use the wheel to adjust it. When in a call use the thumb wheel to adjust the in-call volume. Finally, use the thumb wheel to adjust the volume of multi-media while it's playing. One thing to keep in mind, the master volume will override the multi-media volume, so if you can't hear the multi-media after turning it all the way up, you might try raising the master volume fist.
May 21, 2008 | Motorola Mobility Moto Q
Open Questions:
See all Microsoft LifeChat™ LX-3000 Headset Questions
Microsoft LifeChat™ LX-3000 Headset Logo
100 people viewed this question
Top Microsoft Radio Communications Experts
Ekse
Marvin
Marvin
Chris
Are you a Microsoft Radio Communication Expert? Answer questions, earn points and help others
