If on a mobile, normally it is associated with the recipient in your contact list. May also depend on your type of phone android or ios (iphone) check there contact details in your phone then there is normally further options in there profile, like add to favourites, or list and block / un-block caller.!
On a landline would be simuler in the phone history of callers - block / un-block caller / number. Sometimes it is with the landline exchange sysytem, then call the operator.
While you might be better off leaving it block, :) I would tell you to go and edit her number and somewhere in your contact list on her number there's a spot that says blocked Un block her.
Hello Try these links www.lg.com/us/support-mobile/lg-LS670-Purple - United StatesCached www.starbatteries.com/lgopslsowmau.html www.usersmanualpdf.com/.../free-pdf-lg-optimus-s-ls670-manual-us...Cached
Dial a number which you want to block. Click on end call. From the menu - tap on Logs Icon Tap on the number which you want to block. At the bottom - Middle of the screen, You will find three dots (...) Tap on it. Tap on Block contact. A new screen will come - Block Contact. You will have option to block - Call as well as message.
1) Call 2) Message
Put a check mark and click ok. It will display the number, by saying it is blocked.
Unblock:
From the menu - tap on Logs Icon Tap on the number which you want to Un block. At the bottom - Middle of the screen, You will find three dots (...) Tap on it. Tap on Block contact. A new screen will come - Block Contact. You will have option to un block - Call as well as message.
1) Call 2) Message
Un-check the mark and click ok. It will display the number, by saying it is un blocked.
Usually to permanently unblock the number, you need to contact your phone service provider and ask them to unblock your number. You can then block it per call if wanted by dialing *67 before dialing the number.
