Nothing happens when I go to preheat the oven.
SOURCE: Don't know how to light GE Glow-Bar oven
Perhaps the oven ignitor (glow bar) is defective. To test, check the voltage going to the ignitor when you turn on the oven to bake. If you have 110 volts testing with a voltage meter, replace the ignitor. If you do not have voltage, trougleshoot backwards to see where you have voltage in but not out.
If I can help further, I am here.
Eric Campion
SOURCE: The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
SOURCE: GE JGBP33 gas oven will not light. Burners and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
