Need a replacement battery and charger
SOURCE: battery
To quote Imaging-Resouce.com: He only got about 100 minutes off his battery. Here's what he said:
Slightly better than average battery life for a compact model, but think about buying a second battery anyway. The Canon Powershot SD200 uses a custom rechargeable LiIon battery for power, and uses a custom power adapter, so I couldn't perform my usual direct measurements of its power consumption, but did check how long it would run on a fully charged battery. Like most compact digicams, battery life on the SD200 is a little on the short side, with a worst-case run time (capture mode, with the LCD turned on) of 107 minutes by actual measurement. This is better than many compact and subcompact models, but I'd still strongly recommend purchasing a second battery along with the camera, and keeping it charged as a spare. (Digicam batteries always die at the worst possible times.)
I found this for cheap "Replacement Camera Battery for Canon Powershot SD200 " SKU NB4L103719
$5.42 + s/h at Become.com
To increase battery life, turn off unnecessary features like
any beep feature, reduce the picture review display time, etc.
How many minutes are you getting out of it?
SOURCE: canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
SOURCE: lens error restart camera but
Hi
Your
lens is defective needs to be cleaned, repaired or replaced. If you got sand in the gears it will definitely jam up the lens! Sometimes you can tear down the lens and clean out the sand, and if none of the gears are damaged the lens will then work properly again.
There are online places that will do it for a
decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the
repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
SOURCE: Water problem with canon digital camera
u must let it dry if you did not remove the battery when the unit got wet then its a goner water damage sends electronics to there grave fast! if battery is left in the gold and copper traces start to corode ! and in minutes not days!
