Red light keeps flashing and no drink doming out ?
In my case it was a minor detail: The capsule holder tray has a small magnet on the top right side, you can feel a light pull when you are inserting it in the machine. This magnet became dislodged from the capsule holder, and the machine won't operate and will give you a continuous blinking red light if the magnet is not in place; I found it when emptying a small bin where I put the used capsules. You just have to put it back in place with two drops of glue, or if you can't find it, just order a new capsule holder.
The picture shows the underside of the capsule holder and the magnet next to the slot it came from.
No dolce gusto works with out the capsule holder the megnit holds at the back inside and behind the metal there is a sensor no contact no coffee
Thanks a lot. This solved my problem when I was about to get a new machine...
Thx, solved my problem aw.
Brilliant and thank you very much. We found the magnet on the floor. When this placed back in the tray the machine operated immediately - we are so very grateful.
tank you
Thanks for taking the time to post this! Had the exact same problem, went through various things offered on the internet, but fortunately came across your post! When I told my girlfriend about it she helpfully said "oh yeah ... this bit fell off the other day, didn't know what it was, so I put it aside somewhere". The moment I saw it I knew I'd struck gold. We actually spent more time searching for the damn thing than the actual fix. A blob of superglue and the magnet's snug as a bug in a rug!
And Thanks from me Had the exact same problem,
Thanks. This led to the solution of my problem. Bad contact between the magnet and the sensor due to rust or debris build up.
Like all dolce gusto mini me has safty inside if evry thihg works but water doesnt come or no noise coming from the pump then this can lead you to pump safty blown capsule holder sensor that need replaceing the last thing but needs looking at is the pcb only on manual mini me is semmy auto sow this is good j
Team De-Brewerz.com says:
1. Your coffee maker might suffer from PC board failure. Claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler. You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Red light mean error is this auto if yes you have problems in the gaers at the top were you select the product you have tryed to left the handle before the flashing lights stopped try and press the power bottom until it starts flashing green and run some water only for test if the left and right works then you have problems in the heating
Red light sans error water is the model is it a auto?
Turn on, unplug from mains, plug in again after a few seconds, turn on, after a few seconds w/o be green again.
