I don't know if there's a cheap way to download maps, but your original maps should not 'disappear' in the update as long as you have enough memory in your unit.
Safer way to do this is to load the additional maps on memory card and use that (I take it that you're not taking the trip every week or so, so the maps don't need to be constantly in the device. On the other hand, you can keep the card in to keep the slot from getting dirty.)
Press and hold the on/off button for ten seconds will re-set the system on the satnav. If the screen freezes after loading the maps then connect the Satnav to a pc via a usb lead and download the latest Service update fom Navman.com. With the Satnav connected to the computer and the download compleated double-click the F10 set-up.Exe and it will update the system on the Satnav. Once complete disconnect the cable and restart the F10. That was the way I sorted mine out after recieving 'little' help from Tech Support from Navman.com. My problem seems to be in the Multi-drop ability of the F10 [program one location and try and add another to plan a route] but I have never got anyhelp from the tech's other than "Buy a Connectivity kit from us and you may be able to use that to fix the problem....". If you get a "Not enough memory to complete update... " message after double clicking the F10 set-up, you will need to go into your F10 Satnav memory and look up some of the saved files from previous routes you have stored in there. I deleated some of these to free memory and it didn't seem to affect the Satnav's programming and allowed the update to complete. My F10 started fine after that. If you need any more help, Navman.com tech support may be able to suggest something....., just don't hold your breath....
I just had same problem while trying to load 2008 maps onto N40i . This I unfortunately discovered once I had already removed the existing maps as instructed part of install.
SmartST2006 isn't so smart! It kept saying I wasn't connected to internet when it was registering my product key' despite it most definitely being connected and I had temporarily disabled my AVG firewall just in case it was blocking.
I found an alternative way of registering the maps on the Navman website where it is required to enter the Navman serial number and the maps product key in order to get a code but that didn't work for me either, it didn't recognise my Navman serial despite having been fully registered when new.
My final (desperate) solution worked - find a computer with Win XP install SmartST2006 and hey presto! It took quite a while to load the maps though.
Proof to me that SmartST2006 is not compatible with Vista, if only they had put a slip in the maps box warning of this possibility.
The 'latest' pan Europe maps which are labeled 0408 actually appear to be 1106
Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
