Ice maker stopped making/dropping ice. Had a piece stuck in the 'teeth' used to push ice out of tray. Removed it, has not made ice since. Manually filled the ice tray, it froze, would not **** it into the bucket. Need to remove it so I can thaw and reset the whole unit. I have turned off power to the ice maker, to the refrigerator and unplugged it. None of these has reset the unit.
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
SOURCE: Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
SOURCE: Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
[email protected]
SOURCE: I need help fixing my
THE LITTLE SENSOR GOES UNDERNEITH THE ICE TRAYU IN THE FOAM RIGHT BY THE MAIN ICE MACHINE MOTOR. THERES TWO CLIPS THAT HOLD THE PLASTIC PIECE ON AND LETS THE SENSOR GET A TRY READING ON THE ICE TRAY.
SOURCE: Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
