Tried all the suggested codes from directv receiver and none do anything
It depends on the remote. If you have the long rectangular remote then it will only work TVs, not sound systems. The smaller curvy remote will do sound systems. But not every make.
Programming is done by following the onscreen guide.
If there are no codes for your Onkyo receiver, and there's no way to do a "search all codes" type scan, then you have to acceppt that it's a limit of the remote because it doesn't have the right codes in its memory.
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
SOURCE: i need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with
instructions here.
I hope that helps.
SOURCE: I own an Onkyo av receiver and I want the remote
Samsung Blu-Ray player code for Onkyo universal remotes is 33001.
codes with
instructions here.
I hope that helps.
SOURCE: Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
