I need to find the fuse On my cub Cadet Lawn tractor LXT 1046 VT I think It Is Bad . I am not getting electricity to the starter.
Behind the dash right side try to jump starter if catch then try then go to starter silinoid jump it will try to start if doesnst replace it if dose work go to switch relay beehind dash near fuse let me no what happen
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
SOURCE: cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
SOURCE: Ineed to get the belt routing diagrams for the
GO TO INTERNATIONAL PARTS SITE, ENTER TRACTOR MODEL, SELECT PROPER DECK AND THE PARTS LIST HAS A BELT DIAGRAM BUILT IN. IF YOU HAVE AN INTERNATIONAL BELT FOR IT BEAT A PATH TO A BEARING COMPANY TO ORDER THE SAME OR BETTER BELT FOR LESS THAN 1/4 THE IHC COST.
