Trying to hack family settings
SOURCE: family timer glitch for 360
did you try removing the mains plug, and leaving it off for about 24 hours ??
not sure whether these have a CMOS battery or not.
option 2, if it,s a premium ( with hard Drive ) try removing the hard-drive. Password/Timer probably setting on there rather than the Console.
Mike @ Compurepair.
SOURCE: xbox 360 family timer
Try Unplugging it for an hour or so (like how power outages ask you to set up your console) and ask him if he knows it...
or de attaching the HDD :) it's removable you know!
so much power for a little kid :(
SOURCE: xbox 360 password recovery
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
Hope that helps
Scanss2k
SOURCE: Cannot remember my Xbox 360's passcode and reset answer!
Try these steps first:
Go into settings
.... console settings...then device settings or the
blue screen then go...
left trigger
right trigger
x
y
left bumper
right bumper
left with left stick
up with left stick
right with left stick
x
If that doesn't work then call 1-800-4MYXBOX they will walk you through it.
SOURCE: Forgot password to unlock family settings on xbox 360?
I've managed to come across this from someone who called microsoft with the same problem (it seems quite common)
Go into settings
Console settings
Then device settings (The one with the blue screen)
Then go:
left trigger, right trigger, x, y, left bumper, right bumper,
left with left stick, up with left stick, right with left stick, x
If you have trouble use the pad instead of stick, but I could only get the stick to work..
I hope that helps
Regards
Mike
