Question about Navigon GPS
Canadian routes only
How to calculate a route to Winnipeg from Hamilton using Canadian roads only
6ya staff
SOURCE:
Anonymous
  • 113 Answers
SOURCE: garmin nuvi 200 route calculation problem
Sounds like a major software failure. . .
Hold a finger on the upper right corner of the screen while powering up the unit. This should do a master reset.
The go here to download an update.
Posted on Oct 26, 2007
marcelbakker
Marcel Bakker
  • 174 Answers
SOURCE: no road maps ( Zumo 550
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
Posted on Jun 09, 2008
Anonymous
SOURCE: route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Posted on Jul 21, 2008
geester3
  • 4 Answers
SOURCE: Route calculation Error on Garmin GPSmap 60CSx
Try re-setting your gps by simultaneously pressing the Enter and Page buttons while turning it on if that doesn't work check your firmware i found the latest one v 3.90 would shut off my gps when recalculating v 3.70 is stable Garmin know that the new firmware can cause problems
Posted on Jul 04, 2009
dennis bullard
  • 4090 Answers
SOURCE: Garmin Nuvi Unable to calculate route No roads near starting poin
Its a problem you need to address with Garmin on this model before warranty runs out
Please rate our help to keep the FREE service onlinew++++Thank you for using FIXYA
Posted on Sep 11, 2009
When I try to use it puts me in the wrong location, and doesn't configure route properly.
Routs are calculated, based on, shortest route, fastest route or no toll roads or no highways plus other options. GPS units aren't always accurate. Mine put me into the center of a bar parking lot in a ghetto of Wilmington, when it was supposed to be guiding me to an interstate highway. Make sure, when you have it in use, it is mounted in such a way that it can see the sky DIRECTLY STRAIGHT UP. If you have it at ANY ANGLE, you can throw it off by up to 15 miles.
Dec 15, 2012 | Power Acoustik Navibox-1 Add-on Car GPS...
O8 canadian built chrsyler town and country van serpintine belt routing
What engine? If you google search dayco belts you can find diagrams for just about any vehicle on the road. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 01, 2012 | Cars & Trucks
How do you select most use of freeways to avoid back roads? My Magellan was easy to use in that regard.
Go to the Tools > Settings > Navigation > and press the button under Avoidances.
Use the arrow down and place a check mark in the box beside Unpaved Roads and then press OK.
Also, go to the Tools > Settings > Navigation > and setting the Route Preference to Faster Time will usually route using freeways. This is not always the case, as some secondary roads are paved and the unit will route to them if it calculates that this will be a faster route.
It is usually a good idea to familiarize yourself with an unknown route. This can be done after creating the route and touching the map screen. Zoom out to view sections of the route. Via points can then be added to modify the route as necessary.
Sep 28, 2011 | Garmin nuvi 1450 GPS Receiver
Garmin Nuvi 760 gps Unable to calculate route No roads near starting point
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Aug 02, 2010 | Garmin Nuvi 660 GPS Receiver
Is there a diagram that shows how the vacuum lines hook up for the 2.5 Turbo ?
Vacuum hose routing-1989 2.5L California Turbo I engine
Vacuum hose routing-1990-91 2.2L and 2.5L Federal engines with manual transaxles, and 2.2L and 2.5L Canadian and California engines
Vacuum hose routing-1990-91 2.5L Turbo I California engines
Vacuum hose routing-1990-91 2.5L Turbo I Federal and Canadian engines
Hope helped with this information (remember rated this help) Good luck.
Nov 10, 2009 | 1989 Dodge Daytona
Sep 11, 2009 | Garmin nuvi 350 GPS Receiver
3250 cannot input for canadian routes
install the canadian maps on the unit
if there not there they arent there
Aug 03, 2009 | GPS
Mar 09, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Etrex Vista HCx will not calculate routes.
Please post the co-ordinate of the starting waypoint and I'll check it with mine.
Aug 12, 2008 | Garmin eTrex GPS Receiver
Route calculation error
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
GPS Logo
41 people viewed this question
Top Navigon GPS Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Navigon GPS Expert? Answer questions, earn points and help others
