Bose Solo TV sound system - Black Logo
A
Anonymous Posted on Sep 01, 2014
Red light on not green
The manual states call Bose support. What does the red light mean?
George Scott
Level 3:
Master:
  • Master 789 Answers
  • Posted on Sep 01, 2014
George Scott
Master
Level 3:
Master:
Answers
789
Questions
Helped
228557
Points
2507
Helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
Bose sounlink mini battery blinking red light
If your Bose SoundLink Speaker's battery indicator is flashing red, this usually means the battery has less than 20% charge - and is need of charging. http://worldwide.bose.com/productsupport/en_us/web/article_235_indicator_lights/page.html
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
7helpful
Bose QC 2 Noise Cancelling Headphones the red light is on. Should there be a green light if they are working?
No green light for QC2, just red. If it's constant the battery is charged, powering the noise cancellation, and, if connected to an audio device, conducting sound. If the red light is blinking, the battery is losing its charge.
2helpful
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Top Bose Televison & Video Experts
Paul Bade
john h
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
