SOURCE: Memory Full Error
to use a memory card u have to check the manuel probably u have to buy an mmc card for storing pictures and videos as it is an sd card u have to first dormat it u can do it inside a mobile phone also
SOURCE: camera says my memory is full
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
SOURCE: Samsung S630 Digital Camera, Card Error and Format Error
Some Memory Cards have like a little slide button on the side.If you have been taking the Memory Card out the little button might have been pushed.
Or if you have been taking the card out and sometimes forgeting it was out the pictures will not show up like it is supposed to .THhe unknow pictures without the memory card will sometimes say FORMAT ERROR.
SOURCE: I just bought a new
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Testimonial: "Thanks, I didn't know that! Now I'm just annoyed at the store who sold me the 8GB memory card. Guess I'll have to save that one for later."
SOURCE: My Samsung ES30 camera gives me the DCF Full Error
try to remove the memory card and then format the unit without memory card.,after formatting the unit.,reset it and then format the mmc to the pc.,after 10 seconds.,insert the mmc and then power on again.,
