SOURCE: Turbo air TSF-49SD. I plugged in a used one that
http://www.turboairinc.com/TB-Service/Service.html
Go to this web site. Page down and your model number unit has a picture and service manual. I saw no "H1" error code in the manual. You may want to double check in case I over looked it. You can also call them for further assistance. Sorry I could not be of more help.
SOURCE: Power outage and freezer is now flashing "e" on display
look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
SOURCE: Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
SOURCE: HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
SOURCE: freezer won't get below 13 degrees
Make sure the evaporator coils behind the rear cover inside the freezer are not iced up too much.
This would indicate a defrost problem and will get worse.
If the compressor is still cycling off and on the cold control could be at fault.
