I have had a print-job stuck in the computer/printer for weeks. I have tried cancelling the print via Devices and Printers on my computer without success although it shows up as in the process of being deleted. I have tried to uninstall the printer but system will not let me do hi as it says there is a document waiting to be printed. Do you know how I can clear the document please
SOURCE: Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
SOURCE: lexmark printer problem on HP-UX
You should check your drivers to be sure the Lexamrk ones are being used and that the HP ones have been deleted.
SOURCE: Lexmark 1270 All In One Printer, Scanner, Fax
click start then run
type cmd and click OK
type: net stop spooler
hit enter
type: net start spooler
hit enter
This should clear your print queue without having to reboot your computer.
You could even create a batch file to automate this:
Create a new notepad document and rename it to clrspool.bat or something. Make sure to remove the .txt from the new file, Windows should complain about changing the file type. Open the new file with notepad (Right click it and pick edit). Add the two following lines then save and close the file:
net stop spooler
net start spooler
Just double click the file whenever your print jobs don't clear.
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
