Three long beeps the minings
SOURCE: MSI 848p Neo-v doesn't boot. Beep code error
Hi, your problem might be due to a faulty RAM or Video Crad, try to clean first your RAm and put it back again, then boot up. If the step don't solve the problem then used a different RAM instead, if it doesn't still solve the problem replace your video card with a new one for testing to know if your VGA is working fine. Also check if your PSU is working. Goodluck with that.
SOURCE: msi x58 pro beep codes
If you have a way to get online, then google in Computer beep codes, this should help you out.
SOURCE: graphics still working, Motherboard booting.
you can try to clear the cmos.
if this not works so i think your pci express card slot are dead.
The only thing you can do is to change the motherboard.
maybe you find the same motherboard cheap on ebay.
