Does not turn on
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
SOURCE: francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
SOURCE: I bought a second hand Francis Francis X1 Espresso
Perhaps the heating element is broken. Does it heat up at all? If not, the steamer won't work and there will be nothing for the gauge to register.
SOURCE: Hello I have a Francis Francis X1 and the twin
Is this what you looking for?
http://www.craystoneshop.co.uk/acatalog/FrancisFrancis_Spare_Parts.html
or this?
http://www.craystoneshop.co.uk/acatalog/FrancisFrancis__Coffee_Handles.html
Succes, TonB
SOURCE: My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
