Blodgett DFG-100 Gas Single Oven Logo
A
Anonymous Posted on Aug 30, 2014
Why does my Blodgett conv oven not turning on when I close the door?
Wes Ludlow
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 17, 2014
Wes Ludlow
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2229
Points
5
Check the door switch to see if it is making contact. It is located inside the front cover on right hand side, next to the chain sprocket.
1 Related Answer
Anonymous
  • Posted on Jan 08, 2009
SOURCE: athens controls inc board for old blodgett oven (gas)
Athena still sells this product as a ttc001
call me at 610-729-1032
How to install door hinge on Blodgett oven
Model and serial numbers will help
Blodget zephaire commercial oven not turning on when closing door
open burner panel and checked for door switch first ....good luck
What are the possible sources of the following problem? Our convection oven works fine when it's turned on in the morning. However, when you open the doors for too long, the fan needs a manual push
The oven is designed to turn off the fan if the door is left open too long. I think it is a protection to avoid injury to the user due to heat circulation. It might be best to turn down the heat setting when opening the oven for long periods whilst the cooking is on. If you want the manual it can be downloaded from this site. see page 23.
http://www.blodgett.com/wp-content/uploads/Zephaire-100-G-200-G-ES-man-english.pdf
There is a switch in bottom panel that is part of the igniter it has two wires and has a plunger type connectionype
that is a door switch which locate bottom of panel. If that close ignite will ignite, if the door open the pilot will stop. Hope it help ..good luck
2answers
Blodgett oven mark v 111 can cool down but not cooking
door switch need to be checked or repalce. you can put 2 wires connect together and turn on see motor is running, if it run that mean switch is bac...good luck.
Why do i have no display
Fan is on when first turn on?? Also there is a door switch will click when close it ..check those first and let me kknow....
My company has Blodgett Gas Convection ovens, model # DFG100. Where is the serial number located on these ovens
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
1helpful
2answers
Won't light up
had the same problem, safety gas valve is sticking get a small hammer and tap saftey valve. Just bought a new saftey valve about 3 weeks ago pilot light lite but now flame. I have a blodgett oven made in the 60s. Blodgett is getting away from there swithes that they have been replacing them with a replaceable thermocouple.made by robert shaw. My supplier said that they are not on the market yet. oops! good luck from oswego ny pizza villa.
Top Blodgett Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
