SOURCE: I have a Blodgette/Zephaire Convection Oven. I
I went online to the Blodgette Company. I went to service request and asked the same question. I recieved an answer via e-mail, the items and part numbers need. I then contacted a local distributor for the items needed.
SOURCE: have a zephaire GL when you first turn on the
"sparks pilot lights" , "reset button comes on" can you be more specific on these terms you used? I know this posting is an old posting, but I maybe be able to help you as I have fixed all the problems (multiple with 6 G-L's zephaire. Here I'll try to "assume" your terms. The g-l has one light at the front panel. If you mean it comes on and off (the light that is), this is the due to continuous try ignition module, not reading the "flame sensor input right", assuming there is no flame at the pilot. This might be caused by a mulfunction of the ignition module, or by a bad "flame sensor wire" or sensor. See if the pilot spark / flame comes on when you turn the oven on. See if the white wire coming out of it is good and not chewed by rats or something. If the ingition control (the blue box) is reading flame sensor input right, it will light the main burners, (red wire on the valve) if I recall correctly. The ignition control works properly on max 150 F and the ventilation fan on top if it's not working should be replaced. They sell them on line, and also grainger has it for around $32. The o modules go for around $129 to 170. and sometimes you find them on ebay for around 50. Hope this helps.
H
