Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor  for 56j Frame Motors Ust1152 Logo
A
Anonymous Posted on Aug 30, 2014
Hayward Pump motor, hums but won't start. If I turn the shaft it will keep running but once I turn if off it will not run until I do the same thing again. I have replaced the capacitor but still the s
Hayward Pump motor, hums but won't start. If I turn the shaft it will keep running but once I turn if off it will not run until I do the same thing again. I have replaced the capacitor but still the same problem. I have a hayward 7-193347-01 1.5 - 1.6 hp motor/ SP1514Z2S4EC
Mike Tellegen
Level 3:
  • Hayward Master 1,631 Answers
  • Posted on Sep 05, 2014
Mike Tellegen
Hayward Master
Level 3:
Answers
1631
Questions
Helped
1012374
Points
5840
1 or 2 capacitors on this motor?
Sometimes there are two...
One is a "Start" capacitor and if a 2nd one, that one is a "Run" capacitor.
If only 1 capacitor and you have replaced it... if not a faulty capacitor, then your windings are shot?
When I test a motor with this symptom, I will use the "Clock Face" method of checking for "Dead Spots" on the winding/stator:
Once you have removed the shaft cap on the back of the motor, I presume you have done this since that is only way to turn the shaft manually to get it to run in the manner you described. Place a small mark (1/4" long?) on the outside perimeter of the shaft, say at the 12:00 position. See picture attached...
Then flip switch, does it start or hum?
Then rotate shaft until your mark is now at the 1:00 position. Flip power switch, running or humming?
Do this at all clock positions as you turn/rotate shaft until you reach 12:00 once more. If the pump hums at all clock positions completely dead motor or bad capacitor. If a dead spot is at only one clock position, then absolutely, bad motor - either rebuild or replace.
Coincidentally the motor may stop each time on a dead spot, where the motor won't start due to a fried portion of the stator/winding/armature, only a major repair fixes this. The purpose of the test is to place the position of the stator in a different position in relation to the windings. If humming all the way around, then possibly a bad capacitor, because it is not starting in any position. If it starts say at all positions except 4:00 and 9:00 then motor is bad.
Good luck
Hayward Pump motor, hums but won't start. If I tur - a3442c70-2291-4e69-97d8-6926b8a8b007.jpg
Marco De La Fuente Fernandini
Level 2:
Habit-Forming:
  • Expert 160 Answers
  • Posted on Sep 03, 2014
Expert
Level 2:
Habit-Forming:
Answers
160
Questions
Helped
65484
Points
361
Did you find the correct capacitor?
did you check the ball bearings,maybe there are rusted and now you have the coils in bad condition,that is the reason your motor Humming and no starting.when a coil is over heated the motor does not starts and Humms
5 Related Answers
james aurienne
  • 93 Answers
  • Posted on Jun 07, 2009
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
james aurienne
  • 93 Answers
  • Posted on Jun 18, 2009
SOURCE: my hayward pool pump started making a humming
check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
superdave1
  • 156 Answers
  • Posted on Jul 06, 2009
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Ross Clifton
  • 136 Answers
  • Posted on Nov 06, 2009
SOURCE: I have a hayward 2hp pool pump motor that hums but
your starter capastor has gone bad or got diconnected it`s look`s like round cylender 2 inch by 4 inch dimention`s or it could be an internal (inside the motor) depending how new the motor is
Testimonial: "Thank you very much for your help"
Anonymous
  • 15 Answers
  • Posted on Aug 23, 2010
SOURCE: I have a Hayward power
Jay, to be honest, with all the time your gonna spend searching and trouble shooting the pool is going to turn green and then your going to be stuck with bigger problems. The powerflo pump is a pretty inexpensive pump. Personally id just swap the pump and get it going so the pool stays clear.
Over the winter,tinker with the bad pump and see if you can fix it. If not, trash it. If you can fix it save it for a spare or sell it for 75$ on craigs list and make half your money back you spent on the new one.
Switch is turned on but pump would not run. shaft turns by hand
It's junk made by Hayward. I've gone through two motors and am starting to hear the familiar noise of another motor about to fail.
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
1helpful
I purchased a new 3/4hp Emerson pool pump installed it and the only thing it will do is hum.
OUT THE BACK SIDE OF THE MOTOR IS A SLOT IN THE SHAFT FOR A SCREWDRIVER , SEE IF YOU CAN TURN THE MOTOR OVER(BREAKER OFF !) YOU MAY HAVE BOUND THE IMPELLER OR IT COULD BE SET FOR 230 VOLTS AND YOU ARE RUNNING IT ON 115VOLT.....
IT MAY HAVE A BAD START CAP OR THE SWITCH MIGHT NEED CLEANING. THESE EMERSON MOTORS CAN BE HARD TO WORK ON DO TO THE HUGE AMOUNT OF PLASTIC PARTS
4helpful
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
I have a clicking noise coming from the new Hayward super pump.
Is the motor running? It will make an audible 'click' when it turns on and another as it slows to a stop once shut off. If it keeps doing it during the run time, you are likely not feeding it the correct voltage. Otherwise, one click at the start and end is normal.
If the motor is set for the correct voltage and the line voltage is ok, the motor is starting to fail and will need service at a local electric motor repair shop.
Motor Hums,No Run
Inside the back case on the motor you'll see a white piece with two copper colored arms that have two silver points that almost touch. If these are rusty I've found that the motor won't turn over
. A quick fix is to take some 600+ grit Aluiminum oxide sandpaper and give each of those contact points a brisk sanding to remove any oxidation. This will help the points make a positive contact . Make sure while very obvious that the motor is unplugged first.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
