What is the source of your music? And how it is connected to the receiver? If via HDMI, then it is not possible. Source HDMI device will not put any audio into the HDMI when the display device is not turned on (it must authentificate with the TV to be sure you are not doing any unauthorized copying).
If your only issue is that when you turn off TV it turns off the receiver, then turn on the receiver only after you have turned off the TV. If this causes the TV to turn on also, you have HDMI CEC enabled. HDMI CEC enabled devices to communicate with each other via HDMI - receiver can tell TV to turn on/off. You can disable the HDMI CEC support in receiver menu if you want. After that, your TV and receiver will turn on/off independently of each other.
