Took a break to gas up and then couldn't pull the cord
Hi Mark
Perhaps a bit late now.... Just spotted this so I imagine it's all fixed by now.
But for others with this sort of problem.
Assuming the pull cord is not broken, stuck or tangled. Switch off or short plug to ground, for safety then remove the spark plug to allow the engine compression to escape. You should be able to turn the engine over really easy with the pull rope, otherwise the engine might be seized or the rotary pull mechanism jammed.
Also... can the shaft to the string line be rotated as in the crankshaft of the engine.
Good Luck
