SOON AS U START IT, IT STARTS SQUEALING AN THEN IT GETS LOUDER AN LOUDER
SOURCE: LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.
SOURCE: dryer louder than used to be, does it need service?
The belt may be worn and squealing because it is slipping. When it warms up it stops slipping. It will have to be replaced soon. A worn bearing on a support wheel could also cause intermittent noise.
SOURCE: it starts to squeak as soon as you turn it on and
I have a kenmore elite he4 dryer and I have pulled the bottom front panel off and can see the pulley but it hard to reach. What do i need to pull off to access the pulley?
