Bosch Classixx WFL 2066 Front Load Washer Logo
A
Anne Posted on Aug 30, 2014
Washing machine does not even turn on
Doesn't turn on
The machine doesn't work even in plug
First check that the house circuit breaker isn't tripped. If it seems good, unplug the machine and plug a lamp or something in to check receptical. If all seems good let me know.
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
1helpful
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
1helpful
2answers
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The door of my HMW1070KFL washing machine will not unlock and I cannot get my washing out
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Brand new machine and it doesn;t even wash or spin...did all the installations correctly!
Check to make sure the water is turned on. It is often something simple in this situation.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
