ERROR 100 IS COMING IN 3300 IR. MACHINE THUS MACHINE IS NOT WORKING. I HAD TRIED FOR RECONNECT THE POINTS AND ALSO TRIED TO CLEAN THE LASER UNIT.
SOURCE: canon ir 3300 display shows error E000003-0000
RESETTING CODE E000003-0000 ON CANON IMAGE RUNNER 5000 COPIER
SOURCE: Dear Sir, My canon ir
E585
At the start of the motor CCW operation, the stack handling motor (M2)
may be driven for a specific number of rotations; however, the stack delivery
lever home position sensor (S8) does not go ON.
Cause:
The stack handling motor (M2) is faulty. The stack delivery lever home position
sensor (S8) is faulty, the connector is disconnected, or an open circuit
exits. The stack handling motor (M2) relay harness is faulty. The return
roller is faulty
First try to replace motor.
Hope that helps!
