Heating & Cooling Logo
A
Anonymous Posted on Aug 30, 2014
Why is there a flashing red light on my american freedom 80 air conditioner/heating unit?
Stephen Brisbois
Level 1:
  • Contributor 44 Answers
  • Posted on Aug 30, 2014
Stephen Brisbois
Contributor
Level 1:
Answers
44
Questions
Helped
11395
Points
65
There is a flashing red light on the control board to let you know the board is powered up. It is also used to diagnose errors with the system by counting the number of blinks in between pauses. there should be a legend on the board or in your instructions for the unit.
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 04, 2008
SOURCE: HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
Anonymous
  • Posted on Jun 03, 2009
SOURCE: red light came on and air conditioner will not turn back on
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
Anonymous
  • 70 Answers
  • Posted on Jun 28, 2009
SOURCE: American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Anonymous
  • 37 Answers
  • Posted on Aug 28, 2009
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Anonymous
  • 400 Answers
  • Posted on Nov 19, 2009
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Why is American freedom 80 two stage have a flashing red light?
Red light indicates voltage power to the board. also can be used to diagnose problems with the board or system by counting the number of flashes between pauses. there should be a legend on the board or in your manual.
I have a American Standard furnace Freedom 80 Mod# AUD080C936H3 and am looking for a manal or can you tell me how the exauhst is done. Can I use PVC
Hello, The only time pvc is allowed is if the Furnace is 90% or greater in effiecency, the combustion gases are cooler due to the fact that two heat exvhangers are used. One pipe will be you air intake and the other the exhaust and they can be routed through the roof or sidewall. If the Furnace is 80% then you must use double wall vent pipe and have it connected to either a liner in a chimney or routed through a roof but pvc can not be used.
I changed the furnace filter on my american Standard Freedom 80 filter and now my burner won't light.
does anything happen, i door that you removed might have a kill switch on it so if the door comes off or is not installed right the furnace wont light, let me know and maybe i can help. wally
I have an american standard furnace, freedom 95, Comfort R model that is pushing out air through the ducts. the problem is that it is not giving me hot air. the code is Red, Red/Green, Red, Red/Green, G,...
I have the same furnace, just had the same problem / light code. It was the main board on the furnace thankfully still under warranty. be prepared to get your wallet out!
5helpful
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
I have an American Standard Freedom 80 furnace. When I turn it on it runs and runs and then shuts down and then the cycle starts again. It runs but never ignites. I was wondering if there is anything I...
EIther the valve is faulty or the ingiter is corroded or faulty. The inside of the ingniter has a shaft with a probe that keeps heated so it can ignite. It can be corroded.
Top Heating & Cooling Experts
Paul Carew
john h
