Question about LG Refrigerators
Disassemble lg door in door glide and serve drawer
How does the drawer come apart... I have debris in between the clear plastic and the decorative pieces... How does it come apart?
6ya staff
SOURCE:
SOURCE: Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Posted on Jul 07, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Door outer plastic plate slide down an inch from the top
You would probably need a service manual, for which you can contact LG at 1-800-243-0000 or http://us.lgservice.com
Or locate a local servicer:
http://us.lgservice.com/gcsc/b2c/hpi/main
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Nov 22, 2007
robert samples
  • 1314 Answers
SOURCE: refrigerator
need to know brand locate the serial plate on most brands it's in the refrigerator compartment then i can name your part
Posted on Dec 30, 2007
Anonymous
  • 619 Answers
SOURCE: disassemble
Hi , If you like i have suggestion , do you have vacuum cleaner having small extension can reach to the nest of ants .
Posted on Jan 12, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Getting a small plastic piece out of a door
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 08, 2008
The ice from the ice maker tastes and smells funny.
Look for your Ice maker replcement cartridge at the bottom of your french doors...
Sep 17, 2011 | LG LFC25760ST 25 Cu. Ft. Panorama French...
How do I remove the lights in the refrigerator section of my LG LFC25760ST? Why would the lights not go off, even with the door closed?
this is not really a solution, but good information. this past Just a class action suit was filed against LG for knowing about the light bulb problem and continuing to sell the fridge.
Oct 15, 2010 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
The upper compartment lights will not turn of when you close the doors.
this means your door switch is sticking...most likely needs replacing..
Nov 11, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Ice maker tray
There is a fix for this problem.  Call a qualified LG tech to order the updated metal bar for this icemaker.
Feb 02, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Error Code
dh error code is a defrost problem. You will need to call a qualified LG technician to diagnose and repair this problem.
Nov 25, 2007 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Refrigerators Logo
1,684 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
