There are many native ringtones built in iPhone. You can change the default one to those ringtone at will. Here are detailed steps:
Step 1: Go to Settings on your iPhone.
Step 2: Locate Sound & Haptics under Settings panel.
Step 3: Under Sounds and Vibrations Patterns, choose your own preferred sound you would like to change.
Step 4: Finally, tap Done to finish the change steps.
If you want to make custom ringtone, you can read on this tutorial to learn more: https://all-things-about-apple.blogspot.com/2021/05/how-to-change-iphone-ringtone.html
1.Run Leawo iTransfer and connect iPhone. The software will automatically detect the libraries of the iPhone, and then display the libraries in the left sidebar.
2.Choose Ringtones library and then the contents will be displayed in the right part. If no ringtones are available in your iPhone, you will see an "Add Files" button in the window, and you are allowed to select files from computer. If you have existed ringtones in iPhone, you will need to click "File > Add > Add Files/Add Folder" at the upper right corner to select ringtones from iPhone. Or click "Add" button at the upper left corner; or right-click "Ringtones" library to add ringtones from computer.
3.After selecting ringtones, Leawo iTransfer will begin to transfer ringtones to iPhone. The progress bar will notice the percentage of the transfer process. When the transfer is finished, you will get the ringtones on your iPhone.
BTW, if you wanna transfer ringtone between iPhones, then you may have a look at this practical tutorial: https://bit.ly/38ByujS
Ringtones for the whole phone are set in the Settings app in Sounds-->Ringtones. You can set individual ringtones for any of your contacts in the Contacts app by editing an individual entry. The ringtone (and textone) fields will appear when you touch the "edit" button in Contacts.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
