Push button gas injector does not work
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
