SOURCE: PRINTHEADS
E:0181 means Internal printer timeout. Recommend Action to Resolved this issue
1. Remove the printheads and clean the contact points gently, using a dry, soft, lint-free cloth. Replace the printheads.
2. Remove
the ink cartridges and clean the contact points gently, using a dry,
soft, lint-free cloth. Replace the ink cartridges.
3. Switch the printer off.
4. Remove the power cord. Wait 10 seconds, reconnect the power cord and turn on the printer.
5. If the printer does not resume normal operations, repeat the process three times.
If the error persists, the printer may need repair
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
