Mor flow electric water heater
Http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Hot water heater flow problems.
hey Bookie, those plastic inserts are kinda moulded into the nipples, so taking them out might be more than a feat,...did you solder the pipe to the female adapter ON the nipple? if you did you melted the plastic and that is what's your restricting your flo,......or (believe it or not) the inlet water valve isn't turned on all the way,.....close it then open it,..could have somethin stuck in it. let me know eh? thanks and good luck, cracklin joe
SOURCE: Water works on electric but not on gas it will light but will not keep running
It sounds like your thermal coupler needs to be replaced or maybe just cleaned. P.S. have you tried a different LP tank If its new or the person didn't pressurize the tank when filled you may not have pressure enough to keep the water heater lit.
