Replaced lamp, tv wont come on.. green power light flashing for 30sec then hear a click and light goes red.. fans and color wheel are working
SOURCE: I have a zenith e44w46lcd tv, while watching it,
There a lamp sign the screen right?Put on sergical glove so don't leave finger prints or human sweet could damage somthing else when,power is back to tv for operation.U have a little electronic experience right?U could do it ur self.
SOURCE: Zenith 52
Has Lamp been replaced? Also if Blaster board is bad Lamp will not turn on also CK Fan behind Lamp If it is not running Set will not turn on For Parts Try Encompass 1-800-639-3328 or look on line www.Encompass Parts, Also Look on E-Bay for Lamp and Blaster Board I found Lamp fot mine for 85.00 and blaster board for 55.00Type in Model number it will be on back of your TV.
SOURCE: TV turned off, red and green lights flash for 60.
Yes,u still can hear sound,if the projection bulb is dead.The Ballast board might also dead dead too.The Balllast board help to ignite the projection bulb.
SOURCE: I replaced my bulb 6912V00006C
YES, this set is difficult to replace the lamp correctly---it is very likely when you put the cartridge back into the set the two pins on the back did not properly engage inside the set.
Remove lamp and try again, if set was working before and now different problem, the lamp is not properly seated.
If I remember this model, just the bulb is available, you have to take the housing apart and replace bulb--if not perfectly done plug on back with two pins will not engage.
SD TECH
SOURCE: tv was working fine. turned
you need to replace the lamp This unit has 2 different LAMPS used, one is SQUARE and the other is ROUND.
