Yes you can fix it but do not extend the wire, if it is burned and need to be extended, you have to use a wire that is fireproof and not a regular wire with plastic insulation
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
You did not say what the wire is for, The wires on stoves that are exposed to heat need to be rated for that heat. The insulation is made from special material that wont melt. You can replace or repair the wire but you should troubleshoot it to see why it failed.
